can you actually relocate a curb opening inlet to a new location a couple of feet away?
suppose an existing curb opening inlet is in good shape, can a contractor relocate it to a new location a couple of feet away?
RE: can you actually relocate a curb opening inlet to a new location a couple of feet away?
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East - http://www.campbellcivil.com
But in your scenario, and you are literally talking a few feet, this shouldn't be more involved than excavating around the box, enlarging the opening in the box a bit, scooching it over, cutting the pipe, and bricking up around the pipe.
Now depending on your road grade, getting the hood to match the curb could be a little more involved.
a) remove and replace or
b) build another inlet next to the old one and connect them together.
As I said in my earlier post, this is not a big deal, and occurs a lot more than you probably realize. Its just a box. If the grate ends up high, you trim the top of the box, if it ends up low, you brick it up.
