Parametric Study Material Assignments
I am currently working on a project in ANSYS Workbench with Mechanical. I have imported a Solidworks geometry with parameters and am using a static structural module to simulate a tensile test. I have used named selections to allow parametric studies to be run for different geometries. However, I am receiving the error:
'The Model component in Static Structural for design point 1 requires user input before it can be updated'
The issue is that the assigned materials are being wiped for each design point when the geometry is updated.
How do I ensure that updating the geometry parameters keeps the assigned materials?
Thanks in advance.
Thanks in advance.
RE: Parametric Study Material Assignments
http://ansys24.ir
Solving engineering problems with ANSYS
