LabVIEW, searching tool
I am having a trouble with the large amount of data (1,000s of files) that I am sending to my computer from Labview.
After a while it is impossible to find the file that I want, even if I name the correctly. Does anyone know about an easy searching tool?
Thnks
RE: LabVIEW, searching tool
Everything is a fast windows search tool..
https://www.voidtools.com/
built in windows search?
Not sure why you are having problems finding files if you know the name..
Thank you but "Windows search" is the same as searching manually by name, and I can´t because the quantity of data generated is huge so even though I name them properly. It is normal to get lost in this big quantity of data.
Thank you
yes "Everything" is a different tool.. try it..
I have been using https://rinocloud.com/ so far, its like a blend of a filesystem and a database, its currently in beta - but I can send you an invite.
Some hint about what the basis for the search is would be a big aid in understanding the problem. I'd probably stop using Labview and therefore stop generating uncontrollable numbers of files. If that's not an option I'll need a better hint.
Hi guys,
I chose for Rinocloud https://rinocloud.com/, It has a really good tagginga and comment data tools. But, the best is that it is really easy to integrate with LabVIEW, and everything for free.
It is a VIP stage of the product. But if you want to get access, you only have to contact with the support team and in one day or less, you will have full access.
Thanks em586!
