Olet fitting sizing
Olet fitting sizing
Olet fitting sizing
thread292-326030: Weldolet/Threadolet Trimming
KIWI 2671 may be able to answer my question which relates to the pages 37,38 & 40 of the Bonney Forge catalogue. Does the reference to 'flat' in the tables mean that they produce an olet fitting that can be connected to a flat plate?
Also in the table at the top of page 38 I do not understand the range of run sizes which for 1/8 are listed as;
1/8
1/2
1-3/4
2-1/2-1-1/4
36-3
flat
The 4th and 5th line above don't make sense to me. Can you interpret?
thanks
RE: Olet fitting sizing
Would be better if you cut the original in, but looks like the 4th line means that weldolet can be used for any pipe diameter between 1.25" to 2.5" nominal size
The 5th line means that that fitting can be sued for any nominal sized pipe between 3" and 36".
Yes, flat means that it can be welded to a flat surface, such as a plate.
The Bonney Forge caltalog is available here
Yes, the "flat" designation basically means that for larger radius runs, the curvature is such that the gap between the 'olet and run is maintained within MSS-SP-97 requirements (see "How it Works" on page 38 of the catalog / page 22 of the pdf) regardless of run diameter.
