FOL 3015 AJ Fiber Laser
I am cutting 16 Ga. SS parts 1"x36"" using a tab on each end and the material is bowing quite about .500" what can i do differently in nesting stages? To prevent this from occurring.?
RE: FOL 3015 AJ Fiber Laser
Tab every 12" to 18" reduce or increase as required.
Check if the sheet is stretched levelled by the supplier? if it's not find another supplier that offers it & test that material.
Thanks!
Im very interested as I can't see that additional tabs will make a difference to the finished part, in theory the stress is still in the part it's just not visible until the tabs are broken.
Cheers
Glad to help
