Galvanized pipe cleaning
Dear;
Good morning,
I have received galvanized pipe work with dirt on the outside of the tube I wonder if they know of any solution to clean the tubes because dirt is relatively low.
PS: Mainly spots are indelible marker, earth.
RE: Galvanized pipe cleaning
You might want to try a simple (Hydraulic) Pressure Washer.
Sometimes its possible to do all the right things and still get bad results
