Flange Design per ASME BPV VIII Div 2 Part 5
When I design flange and bolts with ASME BPV VIII-2 Part 5 rules, what stress table should be used for bolt material? Use Section II Part D Table 3 or 4?
For design pressure, Part5 paragraph 5.7.1 requires that flange should be designed per 4.16. Per 4.16, stress table 3 should be used. But for servce stress, Part 5 paragraph 5.7.2 uses Table 4 stresses.
It is pretty confusing, could anybody please give me a help on this?
RE: Flange Design per ASME BPV VIII Div 2 Part 5
Kuan
Another question. 4.16 is Appendix2 flanges. Do you know where Appendix Y flanges is covered in VIII-2?
