The best way to protect a bolt from loosening?
our company is manufacturing machines for wood industry. In certain devices we have a wood log rolling down and hitting the steel wall. At the moment of impact there is a huge amount of energy absorbed. This causes minor movement of the construction elements, and sometimes we get loosened bolts in that part of machinery or nearby.
Therefore now I must research the ways of locking the bolt.
We tried: din 985 nuts, din 127 washers, and Locktite glue. Nothing helps, it keeps loosening. After that we started welding the nuts to the bolts, because it never has to be disassembled, so it is not a problem.
So now I want to familiarize myself deeper with the ways of locking the bolts. I've tried to find the textbook or any other kind of source of information about the usage and differences (in effectiveness of prevailing loosening) of these methods:
din 985 - nut with nylon
din 6923 - nut with expanded bottom and with teeth
din 127 - washer with cut
din 6798 - washer with many cuts
nord lock - from wurth - looks serious, though pretty expensive, haven't tried it yet.
If anybody could advice me where could I find more information on comparison of these locking variants, I would be so grateful. We have other machines with smaller impacts where could avoid welding, but I want to get some theory and lab experiment result before going to "try and hope" routine.
Thank you for your advice
RE: The best way to protect a bolt from loosening?
Consider using a combination of locking methods: liquid thread locking, a prevailing torque nut that isn't nylon (i.e. deformed thread), and a split lock washer.
Using finer thread helps as well.
-Experiential Analysis of Thread Movement by Auburn U.
There's some interesting information in that paper.
It sounds a bit like the bolts are undersized and flex too much on impact.
Another solution might be castle nuts with cotter pin.
Cheers,
Benta.
Check the web site Bolt Science for better information. http://www.boltscience.com/pages/vibloose.htm
Another thing to consider is the use of match-reamed press-fit pins to take the shear load between items so that the movement of parts cannot happen and cannot cause that mode of motion to damage the bolted connection.
Consider bigger bolts, and mechanical anti-rotation devices like french locks or stage 8:
http://stage8.com/
Mike Halloran
Pembroke Pines, FL, USA
I would use Nordlock washers:-
http://www.nord-lock.com/nord-lock/wedge-locking/w...
Just weld the whole thing solid? But off hand, it does sound like bolts are too small.
Bolts holding "sheet metal" together don't have much grip length, so even proper preload is not accompanied by much bolt elongation.
If faying surfaces get buffed down a little when things shift, preload is lost, and the party is over. Using substantial thick walled steel spacers with well finished ends would allow using bolts at least 7 diameters long, and help a lot keeping things tight under duress.
SAE 2014-28-0035
SAE 2007-01-1663
SAE 2007-01-0807
SAE 2006-01-988
SAE 2005-01-1320
J Mech Des v127 (2005) 1191-1197
The best way to prevent the loosening is to prevent the shear force overcoming the friction preloading from the screws. You can use shear pins, or larger fasteners, or more fasteners, or higher fastener preloading. Without more details, it is difficult to select the best solution.
Java999 see my post dated the 11.01.2016
Relying on dowels to resist repetitively varying lateral forces makes me very nervous.
There have been plenty of VW ( four 8 mm dowels) and even Porsche ( eight 8 mm dowels) cranks and flywheels ruined, even in non-abusive passenger car service, when the clamping provided by the "gland nut" was sub-standard after a clutch job.
http://www.aircooledtech.com/8_doweling_crank/4-do...
According to this http://bobhooversblog.blogspot.com/2007/04/4-into-... VW didn't originally use much engagement, but US hot-rodders did, with VW copying the fix.
This (http://www.thesamba.com/vw/forum/viewtopic.php?p=3...) write-up suggests that the dowels have clearance holes in the flywheel, which means they aren't ordinarily carrying shear, so when the nut is loose they just get beaten up as opposed to match-drilled, match reamed, and controlled interference fit.
For reference:
4 cylinders at 3000 RPM is 100 impacts per second; 10,000,000 cycles in 28 hours of operation. Since those dowels aren't press fit in both parts, it is reasonable to see that they are undersized for that sort of duty in the material they are joining.
(3000rev/minute)*(2 strokes/rev)*(1 firing/4 strokes/cylinder) * 4 cylinders * 1 minute/60 seconds = 100 firing/second.
I think it is less about the dowel fits, and more about the limitations inherent in a doweled joint when it comes to dealing with alternating loads.
IF the VW or Porsche gland nut is tightened enough, and IF the dowels fit snug in the flywheel ( they are always danged tight in the crank ) and IF mating faces are carefully detailed, the joint does not move and the dowels remain perfect for the life of the vehicle in reasonable street use. However, Any deficiency in the installed clamping preload, or mating surface condition and parts are ruined.
As you said, probably by zillions of loading cycles.
Note your Samba link has a few responses about "match reaming" the flywheel and crank using a fixture.
That was the standard method of adding 4 dowels to a VW crank/flywheel back in the 70s. Reaming the crank dry, and the flywheel lubricated (or maybe vice-versa) was done to make the crank fit very tight, and the flywheel somewhat dis-assemblable.
How accurately do you think VW or Porsche could make a few million crank and flywheel dowel patterns?
VW and Porsche abandoned dowels as a significant flywheel attachment detail in the 60s, as soon as their engines exceeded 70 HP or 4 cylinders.
From the beginning the Porsche 911 used a bolted flange connection.
https://transporterwerks.files.wordpress.com/2011/...
The VW 4 cylinder "Type 4" abandoned the dowels, save for 1 for "clocking" location purposes.
http://www.volksbolts.com/faq/fly1.jpg
Ask any Chevy or Ford or Dodge racer about what they had to do to upgrade their 6 or 8 bolted flywheel attachment from 160 to 800 or more HP, and they may have bought some better (non-fitted!) bolts for $20.
Factory DURAMAX flywheel attachment is with 8 bolts. ~ 400 HP and over 750 lb-ft (average) torque, delivered in Diesel pulses.
http://www.socaldiesel.com/rawimages/StrokerKit.JP...
If you need to transmit 10,000 HP and maybe 6000 lb-ft of torque reliably ( at least for 10 seconds ) then this is a proven attachment method.
https://i.ytimg.com/vi/KPBCCuFLCXk/maxresdefault.j...
Looks like 8 bolts to me.
Similarly, it used to be pretty standard to attach automotive flanged hubs to rear axles with a key and a taper fit, with a nut torqued to 100 lb-ft or more.
Practically everyone migrated to axles with integrally forged flanges, probably due to issues with loosening and even long term axle breakage. Granted, wheel loading is pretty complex and variable, but securing the wheel and brake hard against the flange with a handful of bolts/nuts is generally pretty reliable. All I have to do is keep the bolts are "tight enough.".
Perhaps simply using twice as many bolts could also work. This would be simpler than match drilling dowel pins.
Ted
As best I can tell it enforces some amount of sliding between the components clamped by the fastener.
I can not imagine that components that repeatedly slide don't eventually wear themselves and the fastener faces down, decreasing preload.
As material is lostEven A fastener that does not "loosen" (unwind) will clamp less and less effectively, and someday will be likely even loosen.
My preferred strategy to achieve reliability would always be to keep the components from sliding in the first place.
As others have said, a quantity of sufficiently long well-tightened fasteners is often a pretty economical, easy-to-field assemble method to accomplish that.
Have you considered trying to dampen the impact forces rather than deliver them directly to your frame structure. If you can add dampened mounts (or even just springs) to this steel wall if could drastically reduce the magnitude of the impact force by spreading the energy out over time.
Also split lock washers are a pet peeve of mine as they preform worse than a flat washer ... at least until the bolt has already become loose.
I have found the NASA fastener design manual to be a good reference, covering the design considerations for bolted connections at a high level.
Bill
It comes in various grades - make sure you're using the correct one.
Also, relies on an 'active surface' for it to work properly. Doesn't work as well on Aluminum or SST because of the inactive surface. There are primers available that may help.
http://www.loctite.com.au/aue/content_data/133403_...
I seem to recall that reference has previously been given to a report (NASA?) that points out the limitations of many retaining methods such as Jam nuts and most variations of locking washers. Additionally some locking methods only ensure the nut doesn't fall off completely - but don't install the preload is maintained.
May have been in this forum: forum725: Welding, Bonding & Fastener engineering
This FAQ also came up when I searched: http://www.eng-tips.com/faqs.cfm?fid=1257
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
http://www.roymech.co.uk/Useful_Tables/Screws/Lock...
I'm assuming the log is falling from a trim saw or sorting machine onto a drag chain or rollers. Many manufacturers use a small ramp to let the log roll past the chain a small distance up the ramp then back onto the chain to reduce the impulse. This can reduce the mass of steel and fasteners needed in the area substantially.
Re the locktite or similar, well prepped bolts with the permanent grades won't likely loosen but require use of a torch to heat them for removal. This can be a problem if the line is inside near the headsaw or planers, trying to clean the floor and machines adequately for hot work isn't fun.
Unless there is a good reason not to, welding with good details to prevent cracks from forming is an excellent option.
Increasing fastener size and switching to fine threads is another option but increasing bolt length and double nutting works well too. Also re: welding nuts to bolts, its better to double nut and weld the two nuts to each other than to weld to the bolt. Much easier to service later, a grinder or sawzall can cut the weld and the relatively cheap nuts removed quickly.
We have also used lock plates and tab washers that index to something on the hardware to prevent rotation. Tab washers are bent/deformed around the bolt head/nut after assembly but lock plates usually need to be installed first. Maybe modify the assembly operation and install a lock plate on the bolt side and torque against that, then use a tab washer on the nut to lock it after torqueing. You can also design the hardware itself to lock one end of the fastener by making it captive (have a slot that locks the faces of a hex bolt, etc).
Load bolts in tension, with long shanks to absorb impact over the length.
I have to agree with bdeuell. deceleration of the item (log) before impact, IMHO ,will lessen the chances
of failure.
You just need to find a fairly heavy spring and don't let them torque them all the way down.
Ted
The helical compression spring can have a much lower spring rate than a helical spring-lock washer, which will make it much less sensitive to vibration loosening. Having said that, I always favor preload as the primary method to avoid vibration loosening.
I think it is still important to understand why the failure is occurring to ensure the solution is appropriate, i.e. is the joint failing because the bolts are not strong enough for the impulse forces they are subjected to or is it failing because vibrations are working the nut loose.
Without a schematic of the production line, it is difficult to visualize how the log strikes the stop plate.
Perhaps it's time to go back to the proverbial drawing board.
What happens to the log after it strikes the plate ?
Where does the log strike the plate ,top, center or bottom ?
More detail is needed !
Would hydraulic damping be of value here ?
Unless we know more about the external forces that the joints experience using a spring behind the nut could make matters worse.
The bolt preload is limited by the amount the spring is deflected and its stiffness, so how do you know what preload to apply if the external forces are unknown?
A bigger problem with the spring and nut arrangement in this particular instance is spring ratcheting, this can happen during any impact and the spring as a tendency to rotate, if this occurs the nut could be slowly rotated off the bolt as the spring relaxes it's preload.
The final problem is also one of spring natural frequency because if the logs hit at regular intervals the spring alone could vibrate and again loosen the joint.
Just to give some idea of what might be involved in maintaining bolt preload using a spring I've attached this link to a paper on using beiville springs for the same purpose:-
http://www.sealing.com/fileadmin/docs/Using_Bellvi...
To use a spring behind each bolted fastener seems an expensive and time consuming option if you want to design it correctly and I don't think this application warrants this.
Bill
... until I heard a rumor about a union nut on a high pressure ball valve that was so thin that it could be stretched enough to jump a thread (without rotation and without fracture of the lockwire) when the face seal o-ring failed.
( Those of you who work in hydraulics know that when a face seal o-ring fails, the effective area producing a separating force goes from the area corresponding roughly to the o-ring ID, to the projected area of the entire face, in this case, roughly the area corresponding to the inside diameter of the union nut, effectively roughly doubling the separating force. )
Of course, it was just a rumor, as was the rumor that the design persisted despite several known service failures, because an engineering vice president held a patent on the particular stupid valve design.
... like that ever happens.
Mike Halloran
In my opinion, the concern here is the impact dynamics. There is no assembly which can sustain great impact energy. EighthBen, you should consider increase your damping devices in a dynamic system before blaming the assembly.
Hope that helps.
Take a hammer & pin punch and hit (in between) the threads of the bolt & nut after tightening (i.e. a DIY deformed thread lock nut).
You'd get spring tension, load distribution, locking, and anti-rotation in one device.
jamnut or castle nut with cotter / wire should then keep it on
why is it bolted if it never needs to be disassembled?
ZCP
www.phoenix-engineer.com
Fair enough ! It is very difficult to troubleshoot a problem when more information is needed !
In an impact area, bolts will have a tendency to loosen through bolt stretch , wear between the faces of the
bolted assy., etc.
A solution to the problem may be had by spring loading the nut to apply more tension as the wear occurs or the bolt
stretches.
Eventually, there is going to be a failure. Impact damping would benefit your problem immensely !
Link
ANY fastener application should always be designed such that components do not move relative to each other. In the world that I work in, and I would venture to guess 99.99999% of other fastener applications, if there is relative movement between parts the joint has already failed, regardless of whether or not parts are actually broken.
However, as we all know, there is no such thing as an infinitely stiff component of any type. Even the largest, most robust parts, if mated together by bolts with sufficient preload to prevent movement between mated surfaces, will still impart extremely minuscule displacements between the opposite ends of a tensioned faster as the parts are loaded. The equations tell us so- even if those displacements are too small to practically measure, or difficult to conceptualize, they are there. These displacements drive the mechanics of fasteners self-loosening, which is relatively well understood.
The Junker test, by using bearings between mating surfaces, simulates this behavior, and also magnifies it to a level where testing preload degradation becomes possible within a practical amount of time.
You could collect the exact same data using a machine without bearings, where a bolt clamped two surfaces together- the problem would be that with sufficient preload, you would need to gather data for days/months/years to develop a useful model, instead of seconds.
If so, I'm thinking both nuts and bolt heads would have to be safety wired, and vulnerable safety wire is going to be on the abused side.
