MMSCFD to m3/hr
MMSCFD to m3/hr
Hi all,
CAn anybody help in the below issue?
how to convert MMSCFD to m3/hr (gas)?
Is it possible to directly convert ft3/day to m3/hr for million quantity? i.e, 1MMSCFD=1179.868m3/hr? Is it correct?
RE: MMSCFD to m3/hr
1 ft3 = 0.0283168 m3 and 1 MMSCFD equals 28,316.8 Sm3/day or ~1,180 Sm3/hr, so your calculation is correct. Just make sure the result is in standard m3/hr, since you have standard cubic foot as well.
Dejan IVANOVIC
Process Engineer, MSChE
RE: MMSCFD to m3/hr
What is this "same pressure and temperature conditions ("standard")" means?
What difference does it make between standard m3/hr and m3/hr?
RE: MMSCFD to m3/hr
Are you unwilling to do ANY thinking for yourself? Two threads down in this very forum is thread798-401538: Use of Nm3/hr Unit which explains this issue in some detail.
David Simpson, PE
MuleShoe Engineering
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual. Galileo Galilei, Italian Physicist
RE: MMSCFD to m3/hr
RE: MMSCFD to m3/hr
