High Build Epoxy or Phenolic Epoxy
Dear experts,
I have fire water storage tanks in my project.
The painting specs from the clients states, internal surface of the fire water tank to be coated by 3 x 100 micron DFT High Build Epoxy or Phenolic Epoxy.
I need some advises for this case.
Which one is the best one ?
Which one is the cheaper one ?
What the different ?
Your advise is highly appreciated.
Syah
Syah
RE: High Build Epoxy or Phenolic Epoxy
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
Which one is the best one ? Phenolic epoxy
Which one is the cheaper one ? High build epoxy (depends on product- High build is just a property, there are many HB epoxies)
What the different ? Resin is different. Phenolic and novolac performs better in immersion services.
CoCoE
Thanks for your response.
We have chosen Phenolic Epoxy after discussion with the client's Coating Inspector.
Syah
So your client has got the same mind of mine, ha ha.
Anyways.. all the best!
CocoE
Off course, the client always want the best one not the cheapest one like the subcontractor :)
Andrew1974,
In the client data sheet there are 2 option PE or HBE.
Syah
Thanks for your advise.
The procedure have been approved based on 3 x 100 micron DFT PE.
