Dimension inferred while Sketching. What is the "best" order / hierarchy?
Hi
I have a question the default settings for dimension inferred while Sketching.
I think I want to move Create length dimensions to the bottom.
Has anyone changed the hierarchy (order)?
What hierarchy (order) you like best?
Also, I always get angles like 140 when I want 40 degrees. Is there a workaround?
I am using NX 8.5.3.3 MP10
Here is a link to a picture:
http://files.engineering.com/getfile.aspx?folder=a...
