Pierce an endpoint of a curve on an existing sketch
I'm a solidworks user, just started working on NX. I can't figure this out by myself. How can I connect the end point of the green curve in the picture right on the circle from previous sketch?
If I first sketch the curve then sketch the circle and use on-point relationship it works. However,I can't do the opposite (When I try to connect the end point of a curve to an existing sketch, like the circle in the picture)... In solidworks you could always use pierce relationship in these situations.
Vahid
Vahid
RE: Pierce an endpoint of a curve on an existing sketch
EDIT : I found it in command search...Intersection point:) Thank you.
Does anyone know some other solutions?
Tim Flater
NX Designer
NX 9.0.3.4 Win7 Pro x64 SP1
Intel Xeon 2.53 GHz 6GB RAM
NVIDIA Quadro 4000 2GB
