Worksheet Change Event will not fire off!
I made a post in the Programming Engineering Languages Forum originally because I didn't know there was a VBA forum.
It is code I wrote in Visual Studio. It handles Siemens NX remotely but I don't think NX is (or the NX API NXOpen) the cause of the problem. However I could be wrong.
The problem is the worksheet change event will not fire off when I click a cell inside the worksheet.
I plan on compiling it into a console application (64 bit).
Hope nobody minds the double post. Thanks.
Here is the post.
http://www.eng-tips.com/viewthread.cfm?qid=401614
Here is the post.
RE: Worksheet Change Event will not fire off!
Is there anything else that is an issue?
Skip,
Just traded in my OLD subtlety...
for a NUance!
