Wafer check valve as a pipe system design boundry
Is a Wafer Check Valve, when subjected to reverse flow, a stop valve for the purpose of pipe design according to ASME Code 34.3? The main purpose of this question is to determine the boundry between system design pressures.
RE: Wafer check valve as a pipe system design boundry
