add *imperfection into .inp file directly, using a text editor
hello every one
i m working to add buckling analysis results (buckling modes) in my main general analysis step as initial geometric imperfection.
whenever i add *imperfection command in abaqus cae (graphic interface) the Intended buckling mode would be added to static analysis as expected but in i need to add the *imperfection command in .inp file directly from matlab environment and despite of right position of *imperfection in .inp file, the abaqus ignore the *imperfection and the analysis would continue without implementing the imperfected geometry to the end.
How could I add *IMPERFECTION to my .inp file directly using a text editor or matlab ?
Thank you.
RE: add *imperfection into .inp file directly, using a text editor
Use a text editor. The input file is a text file.
i know!
as i explained,when i use a text editor and add *imperfection command in .inp file,the abaqus ignore it and the job complete without adding the imperfected shape to main analysis.
but when i import the .inp file in abaqus cae and add the *imperfection command, it works!
I don't believe that. Maybe you still submit the job from /CAE and not the modified .inp on your hard disk.
thanks for respond.
this is my .inp file. maybe the place of *imperfection command in inp structure is not true.
the second command line of *imperfection as well as nodes are ignored here.
*Heading
** Job name: main-base Model name: shahed-main
** Generated by: Abaqus/CAE 6.13-4
*Preprint, echo=NO, model=NO, history=NO, contact=NO
** PARTS
*Part, name=MAIN-1
*Node
*Element, type=S3
*Elset, elset=ALLP, generate
** Section: sec
*Shell Section, elset=ALLP, material=S1MAT
*End Part
*IMPERFECTION, FILE=buck, STEP=1 *********************************
** ASSEMBLY
*Assembly, name=Assembly
*Instance, name=MAIN-1, part=MAIN-1
*End Instance
*Elset, elset=all, instance=MAIN-1, generate
*Elset, elset=peeqset, instance=MAIN-1
*Nset, nset=bot, instance=MAIN-1
*Nset, nset=botnodes, instance=MAIN-1
*Nset, nset=top, instance=MAIN-1
*Nset, nset=topnodes, instance=MAIN-1
*Surface, type=NODE, name=botnodes_CNS_, internal
botnodes, 1.
*Surface, type=NODE, name=topnodes_CNS_, internal
topnodes, 1.
** Constraint: BOT
*Coupling, constraint name=BOT, ref node=bot, surface=botnodes_CNS_
*Kinematic
** Constraint: TOP
*Coupling, constraint name=TOP, ref node=top, surface=topnodes_CNS_
*Kinematic
*End Assembly
*Amplitude, name=AMP-1
** MATERIALS
*Material, name=S1MAT
*Elastic
201000., 0.3
*Plastic, hardening=COMBINED, datatype=PARAMETERS, number backstresses=4
185.,22000., 300., 1600., 120., 6000., 250., 600.
30.,
** BOUNDARY CONDITIONS
** Name: bot Type: Displacement/Rotation
*Boundary
bot, 1, 1
bot, 2, 2
bot, 3, 3
bot, 4, 4
bot, 5, 5
bot, 6, 6
** Name: top Type: Displacement/Rotation
*Boundary
top, 3, 3
top, 4, 4
top, 5, 5
top, 6, 6
** STEP: Step-1
*Step, name=Step-1, nlgeom=YES, inc=1000000000
*Static
0.005, 192., 4.8e-13, 0.05
** Name: topu Type: Displacement/Rotation
*Boundary, amplitude=AMP-1
top, 1, 1, 1.
** OUTPUT REQUESTS
*Restart, write, frequency=0
*Print, solve=NO
** FIELD OUTPUT: F-Output-1
*Output, field
*Node Output
RF, U
*Element Output, directions=YES
E, NFORC, PE, PEEQ, S
** HISTORY OUTPUT: allpd
*Output, history
*Energy Output, elset=all
ALLPD,
** HISTORY OUTPUT: rfbot
*Node Output, nset=bot
RF1,
** HISTORY OUTPUT: topu
*Node Output, nset=top
U1,
*NODE PRINT, GLOBAL=NO, FREQUENCY=1,NSET=top,TOTALS=NO,SUMMARY=NO
U1
*EL PRINT, POSITION=INTEGRATION POINTS,ELSET=peeqset, FREQUENCY=10,TOTALS=NO,SUMMARY=NO
Peeq
*NODE PRINT, GLOBAL=NO, FREQUENCY=1,NSET=bot,TOTALS=NO,SUMMARY=NO
rf1
*End Step
How are you submitting your job? If from inside cae, then cae will overwrite the input file. You need to submit from the command line.
thank you TGS4! you are right!
every time i submitted .inp file from cae, the abaquswould overwrite the .inp file!
i submitted it from command line and the buckling mode added to main analysis
thankyou
