domestic hot water expansion tank
In Massachusetts, does an expansion tank need to have an ASME rating when used on a domestic hot water system, when the tank does not exceed 120 gallons?
RE: domestic hot water expansion tank
1643,
This is a Local Building Code Issue.  Check with your local jurisdiction.  The local building Codes usually refer to the State Code and in some States they refer to one of the "Uniform" Codes.  If this "precedence of Codes leads you to the ASME B&PV Code, it will likely have to have a "U" stamp.  Sorry I could not be more specific.
Also, you might want to ask this question on the Pressure Vessel forum at this site.
Regards, John.
According to an old Boiler Law Synopsis{UBPVLS}-NO-
However suggest you contact The Dept of Public Safety
617-727-3200 Ext.101
