calculate the force of clutch pedal
heeey
i start to make a small tester mechanism I want to calculate the force applied by the driver with his foot on the clutch pedal and the spring because I want take this force and apply it with a pneumatic cylinder to measure the cable life see attached picture
thank you
thank you
RE: calculate the force of clutch pedal
A simple search "clutch pedal foot force" provides many different versions of the same thing, e.g http://www.perceptionenhancement.com/docs/papers/g...
Also you haven't actually asked a question....
Look up MIL-STD 1472 DESIGN CRITERIA HUMAN ENGINEERING. This is available free on the internet, and it will probably tell you want you want to know.
JHG
Mike
Real clutch pedals use a pivot that may provide variable mechanical advantage, and also may include an overcenter assist spring to make the pedal effort lower while applying a greater force to mechanisms downstream, like a cable.
I.e., your layout should accurately reflect the situation in the vehicle for which the clutch cable is intended.
Mike Halloran
Pembroke Pines, FL, USA
If your geometry is right and you cable stretchy enough, you can make your cable into an overcenter spring.
I hate a spongy clutch pedal. Why can't you just use a rod and stiffen it up?
thank you all
i just want to test the cable life and i dont know how to do it the drawing is my idea and didnt know if its right or not
could anyone propose a mechanism to some example of testing the clutch cable life it will be helpful
thank you all
Clutch cable failure was something serious 30 years ago. Nowadays, it just doesn't happen, a bit like the engine always fires first time. I don't understand why you're doing this.
In automotive applications, corrosion is likely the primary culprit. The increasing drag between cable and housing fails the connections.
O/T -- worst cable design ever --- Ford Fox-body Mustangs. My left leg still aches.
