enovia dmu navigator
how can i connect to enovia dmu navigaytor v5?
CATIA.ActiveDocument doesn't work in this case. any materials on that?
RE: enovia dmu navigator
connect to enovia dmu nav...
can you explain?
Eric N.
@JeniaL
From a separate VB.NET application I think it would be the following:
CODE --> VB.NET
System.Runtime.InteropServices.Marshal.GetActiveObject("DMU.application") as INFITF.Application
I'm not sure about from a VBA macro. Possibly:
CODE --> VBA
GetObject(, "DMUV5.Application")
Drew Mumaw
www.textsketcher.com
www.drewmumaw.com
When I start dmu.exe as I start cnext.exe, in VBA I access the application with
dim enoviaApp
set enoviaApp = CATIA
I can change the frame title with
enoviaApp.Caption = "This is Enovia DMU hiding behind CATIA app"
Eric N.
thanks for the answers.
DMU.application work well for me (VBA and external)
