A problem about inserting py cruve into SAP2000
Dear Sir
I am going to analysis the pile deflection on SAP2000 v17 for my fyp research. Firstly, i am using ALLpile to calculate the py curve, Tz curve and Qz curve and I insert the curve by [Define] --> [Section Properties]--> [Link Support Property] and then i choose [multiplastic] and enter such curves into U1(Z-direction) U2(X-direction) and U3(Y-direction) respectively. On the other hand, I insert a load case as [non linear]. After that i carried out the analysis. However, the deflection is highly different from the value that shown on ALLpile. Would anyone can help me? Thank You
I want to add the py curve as similar as the link shown below
http://www.findapile.com/p-y-curves/definition
My set up procedure
https://drive.google.com/file/d/0B55SFUJbBK7tM2hBU...
william
My set up procedure
william
RE: A problem about inserting py cruve into SAP2000
Would you please let me know how to develop the py curve?
