questions about parallel nastran
hello everyone
I am running parallel nastran on linux computer cluster.
the error output is as follow.
anyone have same problems? or just tell me your ideas please~~
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
The NASTRAN software will be removed from Flux during the Jan 2-6, 2016,
maintenance period. NASTRAN is no longer licensed by Flux.
i ran on :
nyx5375
nyx5341
nyx5341
nyx5341
/scratch/jrram_flux/xiaolghe/nast_test/
MSC.Nastran V2012.2 (Intel Linux 2.6.32-504.30.3.el6.x86_64) Fri Dec 18 17:29:43 2015
Determining available hosts, please wait...
DMP task 1: host="nyx5375.arc-ts.umich.edu" sdir="/var/tmp" dbs="c"
*** USER WARNING MESSAGE (pgm: nastran, fn: init_rmt_command)
hosts=nyx5375:nyx5341:nyx5341:nyx5341 (command line[3])
Unexpected failure of remote execution request.
DMP task 2: host="nyx5375.arc-ts.umich.edu" sdir="/var/tmp" dbs="c"
DMP task 3: host="nyx5375.arc-ts.umich.edu" sdir="/var/tmp" dbs="c"
DMP task 4: host="nyx5375.arc-ts.umich.edu" sdir="/var/tmp" dbs="c"
MSC.Nastran beginning distributed job c.
mpirun: Info: plugin plugin002_004_002.so being skipped due to setting of
mpirun: HPMPI_IGNORE_002_004_002 in environment
Parsing application description...
Identifying hosts...
Spawning processes...
map size mismatch; abort
: File exists
: File exists
: File exists
: File exists
: File exists
: File exists
: File exists
: File exists
: File exists
: File exists
: File exists
: File exists
: File exists
: File exists
: File exists
: File exists
: File exists
: File exists
: File exists
: File exists
: File exists
: File exists
MPI_CPU_AFFINITY set to RR, FAILED setting affinity of rank 1 pid 28617 on host nyx5375.arc-ts.umich.edu to ldom 0 (0) code -1
MPI_CPU_AFFINITY set to RR, setting affinity of rank 2 pid 28618 on host nyx5375.arc-ts.umich.edu to ldom 1 (1)
MPI_CPU_AFFINITY set to RR, FAILED setting affinity of rank 3 pid 28619 on host nyx5375.arc-ts.umich.edu to ldom 0 (0) code -1
MPI_CPU_AFFINITY set to RR, setting affinity of rank 0 pid 28616 on host nyx5375.arc-ts.umich.edu to ldom 1 (1)
MSC.Nastran V2012.2 (Intel Linux 2.6.32-504.30.3.el6.x86_64) Fri Dec 18 17:30:19 2015
*** SYSTEM INFORMATION MESSAGE (pgm: nastran, fn: estimate_job_requirements)
Starting ESTIMATE, please wait...
*** USER INFORMATION MESSAGE (pgm: nastran, fn: estimate_job_requirements)
Estimated DOF=9438
Estimated memory=128.0MB
Estimated disk=51.5MB
MSC.Nastran beginning child job c.t0 on nyx5375.arc-ts.umich.edu (master).
Estimated DOF=9438
MSC.Nastran beginning child job c.t1 on nyx5375.arc-ts.umich.edu.
Estimated DOF=9438
Estimated DOF=9438
MSC.Nastran beginning child job c.t2 on nyx5375.arc-ts.umich.edu.
MSC.Nastran beginning child job c.t3 on nyx5375.arc-ts.umich.edu.
Process layout for world 0 is as follows:
mpirun: proc 28597
daemon proc 28600 on host 10.164.5.11
rank 0: proc 28730
daemon proc 28601 on host 10.164.5.11
rank 1: proc 28781
daemon proc 28602 on host 10.164.5.11
rank 2: proc 28776
daemon proc 28603 on host 10.164.5.11
rank 3: proc 28783
MPI Application rank 1 exited before MPI_Finalize() with status 0
mv: cannot stat `./c.t0.f06': No such file or directory
cat: ./c.t1.f06: No such file or directory
cat: ./c.t2.f06: No such file or directory
cat: ./c.t3.f06: No such file or directory
mv: cannot stat `./c.t0.f04': No such file or directory
cat: ./c.t1.f04: No such file or directory
cat: ./c.t2.f04: No such file or directory
cat: ./c.t3.f04: No such file or directory
