Drain a pump body for maintenace
We have open system like cooling tower loop for chillers including two cooling water pumps. If we have to isolate pump for maintenance,is there any requirement of vent a pump body before opening drain nut of a pump body or can we just open a drain nut?
RE: Drain a pump body for maintenace
You can easily get vent plugs which are needle type plugs which don't extend all the way. Just fit one of those if you don't want to fit a valve.
You can also get them as part of the plug - see typical here http://www.technicalspecialties.net/store/Accessor... or this
http://www.seekpart.com/product/Manifold-Drain-Val...
