Caster effect on scrub radius
I'm a student and in the process of designing a offroad buggy. I've retrofitted one in the past but never worked with the front knuckles and hubs.
This might be a silly question, but does caster have an effect on scrub radius? I have the upper and lower ball joints lined up so I have 1" of scrub radius to give the steering a little bit of feel. I have 5 degrees of caster built in as well. This causes the caster line to fall a couple inches in front of the center of the wheel. Is this ok, or should I design it so the caster line is coincident with the center of the tire?
Any help would be greatly appreciated, thanks!
RE: Caster effect on scrub radius
You want the caster to be a positive angle and you want to have positive trail (the steering axis should intersect the ground ahead of the center of the tire contact patch). How much of either one is a darn good question, I know of nothing other than experimentation to pin this down.
I don't know the effect on "feel". I've driven vehicles with supposedly slightly negative scrub radius that have decent steering feel (front-wheel-drive ... means the scrub radius can't be too far from zero to avoid torque steering effects) and I've driven vehicles with supposedly positive scrub radius that have none (most trucks ... the overassisted power steering is to blame).
Thanks again for your help, this just popped into my head while going to sleep last night and I couldn't quite wrap my head around it.
No it does not make sense. When cornering your steering effort is governed by the total side view trail, pneumatic + mechanical.
Which book, and which page?
Cheers
Greg Locock
GregLocock - To be honest I'm not sure exactly which books or exactly what page off the top of my head. I would have to dig through them and find it. As far as I understand, scrub radius does play in a large amount to steering effort. I could be wrong.
Cheers
Greg Locock
1. Scrub radius is the lever arm that transfers longitudinal forces acting on the contact patch(es) back to the steering wheel. This is the source of "torque steer" in FWD vehicles and a similar effect during braking with unequal mu.
2. Weight jacking (inside front wheel pushes down and outside front lifts up) is a product of steering angle, castor angle and scrub radius. The effort required to thus "warp" the suspension is supplied by the driver through the steering wheel.
Not sure how scrub radius contributes to cornering feel. Logic suggests that "trail" is the lever arm that links cornering force and steering effort.
je suis charlie
If (say) the left front brake does more than the right front brake for whatever reason (e.g. unequal slippery surface, or the driver dropping a wheel off the pavement into the adjacent gravel or mud), it is going to impose a yaw moment on the car as a whole which makes the car want to veer to the left. If the scrub radius is slightly negative, that same braking inequality will impose a torque around the steering axis that makes it want to go slightly right. If you are better with these calculations than I am, perhaps you could at least make some sort of estimate of how much negative scrub radius would be needed for these two effects to more or less compensate for each other. I'm just a glorified mechanic so I'd take a stab at it with a general understanding of the effects and fine-tune it with wheel spacers or wheels of different offset until it works right. (with the scrub radius about 10mm, the effect isn't bad enough to make me want to fix it - the effect isn't *that* strong)
Dual diagonal braking circuits in which one circuit fails cause an extreme case of this. IIRC Volkswagen was an early proponent of this (Golf Mk 1) and they made a big deal of their negative scrub radius steering back in the day.
You could likely say that ABS introduces its own set of reasons for doing this, since again it is no longer guaranteed that the left and right front brakes will be doing the same thing at the same time.
If you repeat this mental exercise but for acceleration rather than braking, that's why front wheel drive cars pretty much require a zero or slightly negative scrub radius.
Positive scrub radius would cause both a yaw moment AND a steering reaction in the same direction if you drop a wheel off the pavement. Drop a wheel off and the vehicle takes off into the ditch. I've never understood why it took until the 1970s to figure this out and I still don't understand why vehicles are built with a significant positive scrub radius today. But I'm just a backyard tinkerer. What do I know.
Off roading with a lot of scrub will break your fingers when you hit that "hidden treasure" won't it?
Buggar - Heavy Off-roading is pretty rough on the steering in general. As of now, the plan is to run electric power steering, and a steering stabilizer. Even if the power steering isn't needed (time will tell) I'll definitely run a stabilizer still. The tires are pretty large and the buggy is relatively heavy, so any abrupt motion will definitely yank the wheel right out of your hands.
Caster has it's own pros and cons.
Increasing positive caster, from zero, will increase the difficulty of steering input, so unless you plan on putting power steering in your buggy, more caster means more work.
Some people don't mind that, that is fine, but note that if you are building an off-road buggy, rough terrain and turning the wheel back and forth over ruts, it might play you out.
While caster does offer high speed stability, it also creates jacking forces that "talk" with the diagonal spring from that corner of the vehicle.
If you are moving at a high rate of speed, and you are driving through ruts and turning the wheel left and right to compensate for a loss of traction, it will upset the feel of the vehicle.
While there are times the jacking forces from caster can be beneficial, usually on a "smoother" surface, ruts and bumps are not one of them.
I would personally set my caster as low as possible while still offering steering stability at higher speeds.
Also, keep in mind being in an off-road vehicle, there is a good chance you may get a flat tire at one point. In which case having a negative scrub radius may be beneficial to you in that event..
Same goes for a brake line being ripped off or any thing like that, you never know what happens.
Excessive scrub is also a bad thing, either way positive or negative. It all depends on what you are trying to accomplish.
There are many different ways to go about what you are doing, it all depends on what your personal preference is on the vehicle.
