13R system what constitutes a non combustible stairwell?
The architect of record confirmed to me, in writing, that the fire sprinkler system called for is 13R so I'm covered there.
It's your typical four story motel constructed of wood studs plywood wood trusses pretty much what we see every day.
But the stairwells themselves are a little bit different there's wood studs and two layers of 5/8 drywall but the stairs themselves are constructed of concrete and steel nothing combustible.
On past projects I've always sprinklers underneath the landings and inside the stairwells because the stairs were combustible or made of wood.
I am not sure what to do here, my gut feeling is to sprinkle the entire stairway at each floor level and under each landing, but is that required or can I get away with just top of the stairwell and underneath the bottom landing?
RE: 13R system what constitutes a non combustible stairwell?
Running into this, steel stairs with type III construction, was a new one for me.
