Concrete Interior Temperature
Hello All,
I need to measure the interior temperature of concrete using a thermocouple, thermistor, or RTD .. What specifications do I need?
Thank you.
Thank you.
RE: Concrete Interior Temperature
The Portland Cement Association has similar. Check both organizations for mass concrete placement and control recommendations.
do you need specs for the type of equipment or for the concrete? i only measure the temperature in cases pf extreme weather temperatures or when doing mass concrete pours.
