Temperature Limit Switch Failure
Hi all,
We had a temperature limit switch failure problem in a heat exchange fan control circuit. The fan is a 1/6 HP single phase motor, and it is controlled by a Honeywell 'BM-2R-A2' temperature limit switch. This limit switch is rated for 1/2 HP that shouldn't have any problem in a 1/6 HP case, but it kept failing and the contactor got welded. Does anyone have some insight regarding this? Would you think that adding a surge suppressor would help?
JS
JS
RE: Temperature Limit Switch Failure
Obviously, you could use it as such with added hardware, and that may be the case. Is the switch rated for temperatures
in your application?
Thanks a lot for replying. You can find all the spec via: http://sensing.honeywell.com/honeywell-sensing-mic... and http://sensing.honeywell.com/nomenclature-micro-sw...
The operating range is : -55 °C to 85 °C [-67 °F to 185 °F], and that is sufficient for our case (125 °F).
NOTE: There is no correlation between current rating and HP ratings of switches.
Is there a possibility that the electrical damage is precipitated by mechanical damage due to possible over travel of the operating mechanism?
Bill
"Why not the best?"
Jimmy Carter
Bill, if you look at this tech spec: https://stevenengineering.com/tech_support/PDFs/31.... It says that it is HP rated. Once the contacts close, the moving contact stops, and the over-travel shouldn't have further impacts. Am I understanding it right?
Water or condensation getting to the switch?
______________________________________________________________________________
This is normally the space where people post something insightful.
Keith Cress
Are you trying to limit temperature or what? Sorry, I dont understand. I see only a micro switch
lukin1977
Bill
"Why not the best?"
Jimmy Carter
We also measured the load current. It runs at ~4.5A, with a ~11A inrush on startup.
