Tornado in Garland, TX
I've done a lot of work in Texas, and I was always surprised on the lack of code enforcement there. Maybe some of the local engineers can correct me, but as an example, when I mentioned Special Inspection, I was looked at like a three headed alien. Plan reviews were non existent.
Anyway, mother nature gets her way.
RE: Tornado in Garland, TX
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Professional and Structural Engineer (ME, NH)
American Concrete Industries
www.americanconcrete.com
Maybe a little corruption with the building codes, but then again in most locations the code is written somewhere else, and just adopted without review.
The storms are bad in any location, which is why I don't understand why earth sheltered homes never took off (but that's an engineer thinking). What seems to be most important in the public area, is visual, and price.
Home in areas with water tables near the surface would require above-ground (berm) designs only... Florida, for example, would suddenly become a series of mini hills.
Dan - Owner
http://www.Hi-TecDesigns.com
You just can't fix everything, least you have total government control, and that's not assured given codes not being followed.
If you look at Disney World, it was built up so the streets are on the second floor.
Blame consumers wanting low prices, quality cost $$$.
During new construction hire an engineer to conduct on site inspections for foundation and framing...
Consumers want the lowest price, but there is a government role in assuring that minimum standards are met. It might not serve anyone in the short run, but the government is expected to put out the fires and provide disaster relief. So they need a say in the construction requirements.
There are countries without any building codes. If you scroll down this forum, you can see the results.
Not attaching walls to the slab is not excusable.
