Loose Lintel - Anchor into Backup Wall
I have a 8'0" wide double door with a loose lintel above that is supporting brick veneer. The backup wall is CMU. Should I anchor the loose lintel into the masonry lintel in order to transfer suction forces or it is standard practice to rely on the brick ties? Is another option to design the loose lintel so span horizontally and rely on friction at the jambs to develop the reactions?
RE: Loose Lintel - Anchor into Backup Wall
