NXOpen CreateHolePackageBuilder Class Help
Dear Forum,
I've been developing an NXOpen function for creating couterbore holes on a pointset using the CreateHolePackageBuilder class in the namespace wrokpart.features.CreateHolePackageBuilder. The code works except inside of the logfile it is throwing an error "Failed to commit feature_builder because expected sketch not found" This is strange because the hole series gets instantiated btu this error is appearing within the log file. I've provided the code snippet for my function below.
Any ideas why this is happening and how to fix it?
Thanks.
CODE --> vb.net
Private Function CreateCounterBoreHole(ByVal iPointSet As Features.PointSet, ByVal iBody As Body) As Features.Feature
        Dim holePackageBuilder1 As Features.HolePackageBuilder
        holePackageBuilder1 = workpart.Features.CreateHolePackageBuilder(Nothing)
        holePackageBuilder1.Tolerance = 0.001
        holePackageBuilder1.HolePosition.DistanceTolerance = 0.001
        holePackageBuilder1.HolePosition.ChainingTolerance = 0.00095
        holePackageBuilder1.GeneralHoleForm = Features.HolePackageBuilder.HoleForms.Counterbored
        holePackageBuilder1.GeneralCounterboreDiameter.RightHandSide = "1.0625"
        holePackageBuilder1.GeneralCounterboreDepth.RightHandSide = "0.1"
        holePackageBuilder1.GeneralCounterboreHoleDiameter.RightHandSide = "0.75"
        holePackageBuilder1.GeneralCounterboreHoleDepth.RightHandSide = "1.5"
        holePackageBuilder1.GeneralTipAngle.RightHandSide = "118"
        holePackageBuilder1.StartExtensionEnabled = True
        holePackageBuilder1.HolePosition.SetAllowedEntityTypes(Section.AllowTypes.OnlyPoints)
        Dim features1(0) As Features.Feature
        Dim pointSet1 As Features.PointSet = iPointSet ' CType(workpart.Features.FindObject("PointSet(37)"), Features.PointSet)
        features1(0) = pointSet1
        Dim featurePointsRule1 As FeaturePointsRule
        featurePointsRule1 = workpart.ScRuleFactory.CreateRuleFeaturePoints(features1)
        holePackageBuilder1.HolePosition.AllowSelfIntersection(True)
        Dim rules1(0) As SelectionIntentRule
        rules1(0) = featurePointsRule1
        Dim nullNXObject As NXObject = Nothing
        Dim helpPoint As Point = iPointSet.GetEntities()(0)
        Dim helpPoint1 As Point3d = New Point3d(helpPoint.Coordinates.X, helpPoint.Coordinates.Y, helpPoint.Coordinates.Z) 'New Point3d(-10.4393096814239, 7.58722607614455, 6.63287328868582)
        holePackageBuilder1.HolePosition.AddToSection(rules1, nullNXObject, nullNXObject, nullNXObject, helpPoint1, Section.Mode.Create, False)
        holePackageBuilder1.BooleanOperation.Type = GeometricUtilities.BooleanOperation.BooleanType.Subtract
        Dim targetBodies9(0) As Body
        Dim body1 As Body = iBody ' CType(workpart.Bodies.FindObject("BLOCK(21)"), Body)
        targetBodies9(0) = body1
        holePackageBuilder1.BooleanOperation.SetTargetBodies(targetBodies9)
        holePackageBuilder1.ParentFeatureInternal = True
        Dim oHolefeature As Features.Feature = holePackageBuilder1.Commit()
        holePackageBuilder1.Destroy()
        Return oHolefeature
    End Function
