API 650 TANK FOUNDATION
Hi. Is there a difference between clean washed sand and oiled sand when used as tank based? Because as per API 650, a minimum of 75mm thick clean washed sand is recommended as tank sand base. But existing client's design uses 50mm thick oiled sand. Thanks.
RE: API 650 TANK FOUNDATION
