Autocad R14 Spanish version
I have the spanish version of Autocad R14. In this version all the menus and the help is in Spanish, and the commands of Autocad are translated in the help (the command "circle" is translated to "CIRCULO", for example) but the commands written in the command line when I use menus or the toolbar are the english ones (with the character _ at the begining). The problem is that despite Autocad is in Spanish, It does not recognize the Spanish commands, and it's a real problem because in the help file there are only the Spanish version of the commands!! I'll be grateful if anyone could explain me if it's a common problem or if it's a problem of my version or in fact if anyone could say something about this problem. I think that a solution could be to get the english version of the help but I don't
know how to get it.
Thank you.
know how to get it.
Thank you.
RE: Autocad R14 Spanish version
First, I had the same problem, but now I have solutioned it:
I work now with acad 2000, that has not that problem; it has the commans in spanish (circle-->circulo, line-->linea, etc.).
If so, you can send the file to ABDO and he will have the same commands too.
Otherwise, it is of course possible to copy the english commands into www.BabelFish.com, get their spanish translations and put them into acad.pgp so that typing the commands in spanish on command line will be possible.
Dr. Tigrek
http://members.asiaco.com/tigrek
