Making default Sheet Metal Thickness in NX
I want to make 1.2 mm thickness of sheet metal part and this will (same thickness) required to come when every time i open NX9...
RE: Making default Sheet Metal Thickness in NX
Go to customer defaults, there select sheet metal----->general----->global parameters----->material thickness
there you can enter the value you need(in your case it is 1.2)
apply the changes, then close and reopen the NX
