How to Check in &Check out NX part in Teamcenter
I want check in NX part in Teamcenter .i have created part number in teamcenter
RE: How to Check in &Check out NX part in Teamcenter
In NX right click on the item in assembly navigator and select Check-out or check-in
In Teamcenter find your item, rightclick the NX Dataset (UGmaster or UGpart) and select Check-out/-in...
Couldn't be much simpeler... :)
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX8.5.3 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
This is however not (for concurrent engineering) the most prefered option.
NX8.5.3 / TC9.1.2
HP Zbook15
How to integrate (connect) NX part with Teamcenter,
By using nomenclature i have created a part number...
You can just Start NX from Teamcenter and with file new (in Nx) create a new NXpart which will create an item in Teamcenter for you...
I suggest you get some books or documentation on how to work with NX and Teamcenter...would make it much easier for you :)
NX8.5.3 / TC9.1.2
HP Zbook15
