Any test data for FIELD VANE SHEAR TEST at LOW depth?
I need some reference data (result) of field vane shear test for low depth as 0-5ft. It is needed for research work. Can anyone provide ?
RE: Any test data for FIELD VANE SHEAR TEST at LOW depth?
Or, in using some other info, perhaps you might explain more to see if someone has exactly what you want.
