Reverse loose metal to metal flange: Appendix Y or Appendix 2-13
Hello all,
Can a reverse loose ring flange, that has metal to metal contact outside of bolt circle be designed per Appendix Y? We have a customer that has provided a design and calculations from App. Y and has asked us to review for compliance. I take App. Y to be for metal to metal regular flange configuration (not reverse). By using App. Y, the customer is getting a much thinner flange (1.1" thick) than by using App. 2-13 which yields approximately 3.3" thick. Attached is a simplified detail of the reverse loose flange in question.
Any insight is appreciated if appendix Y can be used in this situation or if 2-13 shall be used.
If appendix Y is applicable, I would consider this flange a class 3 (a flat blind attaches to the flange in question), category 3 (loose flange without a hub) and proceed with applicable equations for calculations from table Y-6.1
Thanks all!
"Success is not final, failure is not fatal: It is the courage to continue that counts."
Winston S. Churchill
RE: Reverse loose metal to metal flange: Appendix Y or Appendix 2-13
of the vessel to the bottom of a drilled hole is insufficient: see UG-43 (g)
r6155
Consider factor y=0 and m=0 for O-ring gasket
r6155
