Couldnt simulate due to this error.
*** ERROR *** CP = 2.980 TIME= 16:16:17
The normal of target element 21737 is not consistent with the normal of
target element 21880 in real set 12. Please use the ENORM command to
correct it.
target element 22633 in real set 12. Please use the ENORM command to
correct it.
The normal of target element 21738 is not consistent with the normal of
target element 22634 in real set 12. Please use the ENORM command to
correct it.
The normal of target element 21739 is not consistent with the normal of
target element 22635 in real set 12. Please use the ENORM command to
correct it.
The normal of target element 21740 is not consistent with the normal of
target element 22636 in real set 12. Please use the ENORM command to
correct it.
The normal of target element 21741 is not consistent with the normal of
target element 22637 in real set 12. Please use the ENORM command to
correct it.
The normal of target element 21742 is not consistent with the normal of
target element 22638 in real set 12. Please use the ENORM command to
correct it.
The normal of target element 21743 is not consistent with the normal of
target element 22639 in real set 12. Please use the ENORM command to
correct it.
The normal of target element 21744 is not consistent with the normal of
target element 22640 in real set 12. Please use the ENORM command to
correct it.
The normal of target element 21745 is not consistent with the normal of
target element 22641 in real set 12. Please use the ENORM command to
correct it.
The normal of target element 21746 is not consistent with the normal of
target element 22642 in real set 12. Please use the ENORM command to
correct it.
The normal of target element 21747 is not consistent with the normal of
target element 22643 in real set 12. Please use the ENORM command to
correct it.
The normal of target element 21748 is not consistent with the normal of
target element 22644 in real set 12. Please use the ENORM command to
correct it.
The normal of target element 21749 is not consistent with the normal of
target element 22645 in real set 12. Please use the ENORM command to
correct it.
The normal of target element 21750 is not consistent with the normal of
target element 22646 in real set 12. Please use the ENORM command to
correct it.
The normal of target element 21751 is not consistent with the normal of
target element 22647 in real set 12. Please use the ENORM command to
correct it.
The normal of target element 21752 is not consistent with the normal of
target element 21856 in real set 12. Please use the ENORM command to
correct it.
target element 22648 in real set 12. Please use the ENORM command to
correct it.
The normal of target element 21801 is not consistent with the normal of
target element 21869 in real set 12. Please use the ENORM command to
correct it.
target element 22088 in real set 12. Please use the ENORM command to
correct it.
The normal of target element 21802 is not consistent with the normal of
target element 22087 in real set 12. Please use the ENORM command to
correct it.
The normal of target element 21803 is not consistent with the normal of
target element 22086 in real set 12. Please use the ENORM command to
correct it.
The normal of target element 21804 is not consistent with the normal of
target element 22085 in real set 12. Please use the ENORM command to
correct it.
The normal of target element 21805 is not consistent with the normal of
target element 22084 in real set 12. Please use the ENORM command to
correct it.
The normal of target element 21806 is not consistent with the normal of
target element 22083 in real set 12. Please use the ENORM command to
correct it.
The normal of target element 21807 is not consistent with the normal of
target element 22082 in real set 12. Please use the ENORM command to
correct it.
The normal of target element 21808 is not consistent with the normal of
target element 22081 in real set 12. Please use the ENORM command to
correct it.
The normal of target element 21809 is not consistent with the normal of
target element 22080 in real set 12. Please use the ENORM command to
correct it.
The normal of target element 21810 is not consistent with the normal of
target element 22079 in real set 12. Please use the ENORM command to
correct it.
The normal of target element 21811 is not consistent with the normal of
target element 22078 in real set 12. Please use the ENORM command to
correct it.
The normal of target element 21812 is not consistent with the normal of
target element 22077 in real set 12. Please use the ENORM command to
correct it.
The normal of target element 21813 is not consistent with the normal of
target element 22076 in real set 12. Please use the ENORM command to
correct it.
The normal of target element 21814 is not consistent with the normal of
target element 22075 in real set 12. Please use the ENORM command to
correct it.
The normal of target element 21815 is not consistent with the normal of
target element 22074 in real set 12. Please use the ENORM command to
correct it.
The normal of target element 21816 is not consistent with the normal of
target element 21845 in real set 12. Please use the ENORM command to
correct it.
target element 22073 in real set 12. Please use the ENORM command to
correct it.
*** ERROR *** CP = 3.011 TIME= 16:16:17
The normal of target element 12081 is not consistent with the normal of
target element 12712 in real set 13. Please use the ENORM command to
correct it.
The normal of target element 12084 is not consistent with the normal of
target element 12709 in real set 13. Please use the ENORM command to
correct it.
The normal of target element 12089 is not consistent with the normal of
target element 19897 in real set 13. Please use the ENORM command to
correct it.
The normal of target element 12092 is not consistent with the normal of
target element 12476 in real set 13. Please use the ENORM command to
correct it.
The normal of target element 12129 is not consistent with the normal of
target element 12465 in real set 13. Please use the ENORM command to
correct it.
The normal of target element 12132 is not consistent with the normal of
target element 12468 in real set 13. Please use the ENORM command to
correct it.
The normal of target element 12149 is not consistent with the normal of
target element 19906 in real set 13. Please use the ENORM command to
correct it.
The normal of target element 12152 is not consistent with the normal of
target element 13444 in real set 13. Please use the ENORM command to
correct it.
The normal of target element 12225 is not consistent with the normal of
target element 13433 in real set 13. Please use the ENORM command to
correct it.
*** ERROR *** CP = 3.042 TIME= 16:16:17
The normal of target element 12228 is not consistent with the normal of
target element 13436 in real set 13. Please use the ENORM command to
correct it.
The normal of target element 12233 is not consistent with the normal of
target element 19895 in real set 13. Please use the ENORM command to
correct it.
The normal of target element 12236 is not consistent with the normal of
target element 13208 in real set 13. Please use the ENORM command to
correct it.
The normal of target element 12273 is not consistent with the normal of
target element 12969 in real set 13. Please use the ENORM command to
correct it.
The normal of target element 12276 is not consistent with the normal of
target element 12972 in real set 13. Please use the ENORM command to
correct it.
The normal of target element 12281 is not consistent with the normal of
target element 12985 in real set 13. Please use the ENORM command to
correct it.
The normal of target element 12284 is not consistent with the normal of
target element 17224 in real set 13. Please use the ENORM command to
correct it.
The normal of target element 12321 is not consistent with the normal of
target element 12945 in real set 13. Please use the ENORM command to
correct it.
The normal of target element 12324 is not consistent with the normal of
target element 12948 in real set 13. Please use the ENORM command to
correct it.
The normal of target element 12341 is not consistent with the normal of
target element 12961 in real set 13. Please use the ENORM command to
correct it.
The normal of target element 12344 is not consistent with the normal of
target element 17252 in real set 13. Please use the ENORM command to
correct it.
The normal of target element 12417 is not consistent with the normal of
target element 12492 in real set 13. Please use the ENORM command to
correct it.
The normal of target element 12420 is not consistent with the normal of
target element 12489 in real set 13. Please use the ENORM command to
correct it.
The normal of target element 12425 is not consistent with the normal of
target element 12937 in real set 13. Please use the ENORM command to
correct it.
The normal of target element 12428 is not consistent with the normal of
target element 17228 in real set 13. Please use the ENORM command to
correct it.
*** ERROR *** CP = 3.260 TIME= 16:16:17
The normal of contact element 12105 is not consistent with the normal
of contact element 12936 in real set 12. Please use the ENORM command
to correct it.
The normal of contact element 12108 is not consistent with the normal
of contact element 12933 in real set 12. Please use the ENORM command
to correct it.
The normal of contact element 12113 is not consistent with the normal
of contact element 21231 in real set 12. Please use the ENORM command
to correct it.
The normal of contact element 12116 is not consistent with the normal
of contact element 12488 in real set 12. Please use the ENORM command
to correct it.
The normal of contact element 12177 is not consistent with the normal
of contact element 12477 in real set 12. Please use the ENORM command
to correct it.
The normal of contact element 12180 is not consistent with the normal
of contact element 12480 in real set 12. Please use the ENORM command
to correct it.
The normal of contact element 12197 is not consistent with the normal
of contact element 21240 in real set 12. Please use the ENORM command
to correct it.
The normal of contact element 12200 is not consistent with the normal
of contact element 13456 in real set 12. Please use the ENORM command
to correct it.
The normal of contact element 12249 is not consistent with the normal
of contact element 13445 in real set 12. Please use the ENORM command
to correct it.
The normal of contact element 12252 is not consistent with the normal
of contact element 13448 in real set 12. Please use the ENORM command
to correct it.
*** ERROR *** CP = 3.292 TIME= 16:16:17
The normal of contact element 12257 is not consistent with the normal
of contact element 21229 in real set 12. Please use the ENORM command
to correct it.
The normal of contact element 12260 is not consistent with the normal
of contact element 13432 in real set 12. Please use the ENORM command
to correct it.
The normal of contact element 12297 is not consistent with the normal
of contact element 12981 in real set 12. Please use the ENORM command
to correct it.
The normal of contact element 12300 is not consistent with the normal
of contact element 12984 in real set 12. Please use the ENORM command
to correct it.
The normal of contact element 12305 is not consistent with the normal
of contact element 13209 in real set 12. Please use the ENORM command
to correct it.
The normal of contact element 12308 is not consistent with the normal
of contact element 18558 in real set 12. Please use the ENORM command
to correct it.
The normal of contact element 12369 is not consistent with the normal
of contact element 12957 in real set 12. Please use the ENORM command
to correct it.
The normal of contact element 12372 is not consistent with the normal
of contact element 12960 in real set 12. Please use the ENORM command
to correct it.
The normal of contact element 12389 is not consistent with the normal
of contact element 12973 in real set 12. Please use the ENORM command
to correct it.
The normal of contact element 12392 is not consistent with the normal
of contact element 18586 in real set 12. Please use the ENORM command
to correct it.
The normal of contact element 12441 is not consistent with the normal
of contact element 12716 in real set 12. Please use the ENORM command
to correct it.
The normal of contact element 12444 is not consistent with the normal
of contact element 12713 in real set 12. Please use the ENORM command
to correct it.
The normal of contact element 12449 is not consistent with the normal
of contact element 12949 in real set 12. Please use the ENORM command
to correct it.
The normal of contact element 12452 is not consistent with the normal
of contact element 18562 in real set 12. Please use the ENORM command
to correct it.
*** ERROR *** CP = 3.853 TIME= 16:16:18
The normal of contact element 21705 is not consistent with the normal
of contact element 21868 in real set 13. Please use the ENORM command
to correct it.
of contact element 22441 in real set 13. Please use the ENORM command
to correct it.
The normal of contact element 21706 is not consistent with the normal
of contact element 22442 in real set 13. Please use the ENORM command
to correct it.
The normal of contact element 21707 is not consistent with the normal
of contact element 22443 in real set 13. Please use the ENORM command
to correct it.
The normal of contact element 21708 is not consistent with the normal
of contact element 22444 in real set 13. Please use the ENORM command
to correct it.
The normal of contact element 21709 is not consistent with the normal
of contact element 22445 in real set 13. Please use the ENORM command
to correct it.
The normal of contact element 21710 is not consistent with the normal
of contact element 22446 in real set 13. Please use the ENORM command
to correct it.
The normal of contact element 21711 is not consistent with the normal
of contact element 22447 in real set 13. Please use the ENORM command
to correct it.
The normal of contact element 21712 is not consistent with the normal
of contact element 22448 in real set 13. Please use the ENORM command
to correct it.
The normal of contact element 21713 is not consistent with the normal
of contact element 22449 in real set 13. Please use the ENORM command
to correct it.
The normal of contact element 21714 is not consistent with the normal
of contact element 22450 in real set 13. Please use the ENORM command
to correct it.
The normal of contact element 21715 is not consistent with the normal
of contact element 22451 in real set 13. Please use the ENORM command
to correct it.
The normal of contact element 21716 is not consistent with the normal
of contact element 22452 in real set 13. Please use the ENORM command
to correct it.
The normal of contact element 21717 is not consistent with the normal
of contact element 22453 in real set 13. Please use the ENORM command
to correct it.
The normal of contact element 21718 is not consistent with the normal
of contact element 22454 in real set 13. Please use the ENORM command
to correct it.
The normal of contact element 21719 is not consistent with the normal
of contact element 22455 in real set 13. Please use the ENORM command
to correct it.
The normal of contact element 21720 is not consistent with the normal
of contact element 21844 in real set 13. Please use the ENORM command
to correct it.
of contact element 22456 in real set 13. Please use the ENORM command
to correct it.
The normal of contact element 21769 is not consistent with the normal
of contact element 21857 in real set 13. Please use the ENORM command
to correct it.
of contact element 21896 in real set 13. Please use the ENORM command
to correct it.
The normal of contact element 21770 is not consistent with the normal
of contact element 21895 in real set 13. Please use the ENORM command
to correct it.
The normal of contact element 21771 is not consistent with the normal
of contact element 21894 in real set 13. Please use the ENORM command
to correct it.
The normal of contact element 21772 is not consistent with the normal
of contact element 21893 in real set 13. Please use the ENORM command
to correct it.
The normal of contact element 21773 is not consistent with the normal
of contact element 21892 in real set 13. Please use the ENORM command
to correct it.
The normal of contact element 21774 is not consistent with the normal
of contact element 21891 in real set 13. Please use the ENORM command
to correct it.
The normal of contact element 21775 is not consistent with the normal
of contact element 21890 in real set 13. Please use the ENORM command
to correct it.
The normal of contact element 21776 is not consistent with the normal
of contact element 21889 in real set 13. Please use the ENORM command
to correct it.
The normal of contact element 21777 is not consistent with the normal
of contact element 21888 in real set 13. Please use the ENORM command
to correct it.
The normal of contact element 21778 is not consistent with the normal
of contact element 21887 in real set 13. Please use the ENORM command
to correct it.
The normal of contact element 21779 is not consistent with the normal
of contact element 21886 in real set 13. Please use the ENORM command
to correct it.
The normal of contact element 21780 is not consistent with the normal
of contact element 21885 in real set 13. Please use the ENORM command
to correct it.
The normal of contact element 21781 is not consistent with the normal
of contact element 21884 in real set 13. Please use the ENORM command
to correct it.
The normal of contact element 21782 is not consistent with the normal
of contact element 21883 in real set 13. Please use the ENORM command
to correct it.
The normal of contact element 21783 is not consistent with the normal
of contact element 21882 in real set 13. Please use the ENORM command
to correct it.
The normal of contact element 21784 is not consistent with the normal
of contact element 21833 in real set 13. Please use the ENORM command
to correct it.
of contact element 21881 in real set 13. Please use the ENORM command
to correct it.
NUMBER OF WARNING MESSAGES ENCOUNTERED= 3
NUMBER OF ERROR MESSAGES ENCOUNTERED= 120
im having problem simulating due to this problem.
can someone help me?
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
to correct it.
RE: Couldnt simulate due to this error.
http://ansys24.ir
Solving engineering problems with ANSYS
