Auto size for bolt by changing hole Dia.
Hello Everyone.
I want to know that how can i Auto change bolt size when i change hole diameter.
I attach two plate with bolted connection and i want inventor to auto select bolt size when i change hole dia in both two plate, is it possible???
thanks
RE: Auto size for bolt by changing hole Dia.
Did you turn on Autosolve instead of Manual with the Bolted Connection? I know that will automatically adjust length, but I don't recall if it will auto adjust bolt size.
