Catia-Core and Cavity
why I don´t see, when I make pulling direction, surfaces. I don` have core and cavity surfaces in a tree structure.
Please hepl me.
Please hepl me.
RE: Catia-Core and Cavity
You can create your own cavity/core structure using different partbodies to model the core and subtracting it (using a boolean operation) from the cavity. The result will be your plastic injection part.
CATIA also has an add on workbench called Functional Molded Part (FMP) that helps you design cast, molded, and forged parts along with the corresponding tooling.
Drew Mumaw
www.textsketcher.com
www.drewmumaw.com
