ASME UHX - TUBESHEET THICKNESS DECIDE
RE: ASME UHX - TUBESHEET THICKNESS DECIDE
ChiangJaron, assuming you are under Part UHX, your dimension "T" corresponds to the Part UHX variable "h". Dimension "hg" should be an input and is accounted for in "h". See UHX-12.3 Nomenclature and Fig UHX 12.1 sketch (d).
You don't show a thickness dimension for the rim at the bolt circle, but if bolt loads are transferred thru it, it is subject to the rules of UHX 9. If bolt loads are not transferred then dimension "T-2*H2" is subject to the same.
Mike
