SHOW INFORMATION WINDOW won't stay checked
After performing a measure distance I always have to check the "show information window" under "results display". Nx9 doesn't remember to keep this checked. Is there a customer defaults setting for this???
RE: SHOW INFORMATION WINDOW won't stay checked
-Dave
NX 9, Teamcenter 10
Tomas
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Does it work with NX10?
thank you!
UGII_UIFW_SAVE_MEMORY_ON_CANCEL=ON
Now keep in mind that officially this is a totally unsupported 'fix'. Now I've been using it since NX 7.5 (BTW, it was created per my personal request since it helped to make my demos flow a bit smoother if I didn't have to go back and start over filling in the options on a dialog if I was forced to cancel for some reason) and have had no real problem except that there are a few situations (which I can't recall at the moment) where this has no effect, but those are rare (and they will not be fixed).
So anyway, give it a shot if you wish to. At least, I think it helps to keep things moving more smoothly, but that's only my humble opinion.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
