Stapled Connections
Stapled Connections
Stapled Connections
Does anyone have any references or information about staple capacities in structural applications (osb gusset to 2x wood framing)?
Apparently the NDS is mum on the situation.
RE: Stapled Connections
Chapter 23 of the IBC has diaphragm shear values for stapled plywood.
We have it here in Canada as well but only under the PWF foundation manual CSA-S406. I don't believe the CSA-O86 has values yet.
If you haven't found it already, ISANTA has a current evaluation report, ESR-1539, with staple capacities. ISANTA may have additional information on there website: http://www.isanta.org/
Yeah I did some research into this a while back. I think I ended up using the equations in the ESR-1539 report. Bascially they are treated like nails using the staple diameter so basically 2x nail strength for each staple (if I am remembering correctly)
EIT
www.HowToEngineer.com
