ABAQUS/Explicit: Anti-aliasing filter minimum output intervals
So I checked on Anti-aliasing filter in history and field output request, and the following warning message pops up -
The number interval used on *field, output, filter=antialiasing may be too small to construct an acceptable cutoff frequency for filtering. The cutoff frequency of this filter was changed to a higher value, corresponding to a time frequency of 200 field frames.
Is there any guideline about the minimum number of intervals requested? For example, the Default in History output request is 200, and Field output request is 20 (for evenly spaced time intervals).
I had requested 100 intervals in my analysis, see below -
RE: ABAQUS/Explicit: Anti-aliasing filter minimum output intervals
