Non metallic material Testing as per Annex F API 6A
Dear All,
I want to do non metallic material testing as per F.1.13 Testing of non metallic seals API 6A.
there are two test : one is immersion test and other is fixture test.
Do anyone have procedure for that ? I have read this API 6A cause. but little worried because hydrocarbon media.
what is the risk factor for testing a seal at 325 deg temp . with 1000 PSI pressure with hydrocarbon media?
Kamlesh
Kamlesh
RE: Non metallic material Testing as per Annex F API 6A
