Contour Integral at interface between different materials
Hi all,
I need to calculate the j-integral at the interface of two different materials with significally different stiffnesses. If I use two materials with nearly the same stiffness in this model the analysis works well. But if the stiffnesses differ significally the analysis doesn't converge. Does anyone know a workaround to make it run anyway?
