Bush and Roller both made of Delrin?
Hi, Am a newcomer to the site and looking for assistance - Have a food grade application wherein both a bush and the sleeve turning within need to be a plastic.
Someone suggested to make both of Delrin, but another suggestion was it may wear faster due to both being of same materials. Can you please suggest a good combination
of food grade plastics for a bush-roller combination. We tried SS304 for the roller and Delrin for the bush.. but the SS roller seems to abrade faster than anticipated.
(the bush is about 50 mm dia and bore of 40 mm, and roller rpm is aboout 300).
RE: Bush and Roller both made of Delrin?
H
www.tynevalleyplastics.co.uk
It's ok to soar like an eagle, but weasels don't get sucked into jet engines.
Dr. Chris DeArmitt
President
Expert plastic materials help
www.phantomplastics.com
Acetal and a polyester are often run together (mainly for gears as they are quiet in combination).
H
H
