How to provide a plastic hinge in SAP2000 based on indian codes?
Dear all,
I am doing a simple pushover analysis in SAP2000.I did analysis by user defined hinges based on P-M interaction and Moment-Curvature diagrams which are calculated manually.But if i consider default hinges,then the results are entirely different.It may be due to the fact that SAP default hinges are based on FEMA 356.
So,I want to know that , is there any way by which we can assign default hinges as per Indian codes.
I am using SAP2000v14.0.
Thanks in advance.
Thanks in advance.
