View rotation in Drafting application
Is it possible to rotate a view in drafting application? e.g. My bottom view is not oriented exactly as I want, my wish is to rotate it at 90 degrees in order to save some space(the same view but different direction). Is there any options do rotate it or I shall rethink it in the 3D mode?
Thank you.
Thank you.
RE: View rotation in Drafting application
Right click on the view - Settings - Angle and then set your desired angle.
