PAC Slurry Dosing Suytems
thread164-41936: PAC slurry pumping
Hi I need some basic design information on PAC slurry dosing systems, capable of achieving 30-50mg/l for pesticide removal as part of a drinking water treatment process stream.
What does the system comprise of - ie bulk PAC storage tank, day tank, pumps?
How is PAC to be dosed - eg concentrations in the day tank, carrier water requirements, wetting and mixing of PAC etc
kind regards
kind regards
RE: PAC Slurry Dosing Suytems
On smaller systems, feed control is achieved by regulating the flow of dry carbon through a dry feeder equipped with a slurry pot.
Carbon slurry piping systems are designed to provide approximately 1 gal/lb of carbon. Velocities 3.5 to 5 ft/sec are best.
Talk to your metering pump supplier but they usually have stainless steel bodies.
Dust can be an issue when you are batching up the slurry.
I assume you have done the labwork on the pesticide removal because some pesticides like atrazine are not removed very effectively with PAC.
Ashtree
"Any water can be made potable if you filter it through enough money"
