NX 7.5 object color change
In modeling, when I change color only of a face on the object, it makes me problem sometimes.
How I can remove color of the face (reset face color to the body color) so the whole body is with the same color?
RE: NX 7.5 object color change
Select the Solid Body, press MB3 and select the 'Edit Display' option. Now go to the 'Settings' section of the Edit Object Display dialog and toggle ON the 'Apply to All Faces of Selected Body' option. Now select the 'Inherit' button and using the cursor, pick one of the faces that's already the desired color and then hit OK.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
John, you and some more guys are just so good in NX. You guys make this forum to be a wish basket. Just got a problem with NX, go here and ask for THE answer, D-O-N-E, pronto.
