Text "after leader" vs "above stub" or "over stub"
How do I get my leader text to be located after the leader instead of above or over the stub of the leader? See the attached jpg. The upper leader is what I want, the lower is what I don't want.
Thanks!
Thanks!
Thank you,
Trent
NX 9.0.3.4
RE: Text "after leader" vs "above stub" or "over stub"
Dimension -> Text -> Orientation and Location
...and change the 'Orientation' to 'Horizontal Text'
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
The variable that you suggest I change was already set to "text after stub". Any other suggestions?
Thank you,
Trent
NX 9.0.3.4
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
