Straight thread for Category D Fluid
Hi engineers,
In para. d of 314.2.1 of ASME B31.3, it is written that "A coupling having straight thread may be used only for Category D Fluid Service, and only with taper-threaded mating components.". Why not straight mating thread? As I know straight threads are straight for both mating threads.
Any reply will be highly appreciated!
RE: Straight thread for Category D Fluid
I am face same problem with here if You have any solution provide me.
Hi Brasol,
Is that you handshaking with Barak?
The reason is that without the taper thread, the sealing surface is the end of the pipe, not the threads. The end of the pipe could be a small area, insufficient to bear on any gasket or seal. In addition all the sealing force is on the pipe end and gasket and a small movement of the coupling would start a leak.
Figure 335.3.3 provides for accepted use of straight threads, but note the stub on the piping which actually bears on the sealing surface.
A straight thread onto a straight threaded coupling could just screw right over it or leave one part with only a small portion of the coupling if the coupling has no inside lip.
Thanks littleinch for your reply.
I've no problem with straight-to-straight threads, but straight-to-tapered is my problem. Why not tapared-to-tapered or straight-to-straigh with gasket (for category D)?
Tapered to tapered isn't an issue and isn't noted in section 314.
Straight to straight (specifically for a coupling) is clearly seen as something by the committee as historically something having a higher failure rate or even fundamentally unsafe / unsecure. The difficulty of getting a gasket to seal on the end of a threaded pipe section is clearly open to error and misalignment of the gasket or coupling and too small a bearing area to properly seat a gasket.
Just because it is category D doesn't mean it's not dangerous if it leaks or the coupling fails. Cat D can be up to 10 bar / 150 psi and up to 186 C / 366F. The fluid might not be harmful to human tissues, but I wouldn't want to be hit by a jet of fluid at 180C coming at me with 10 bar behind it....
Personally I distrust all things whereby the thought process is "Oh it's only water / cat D / temporary " therefore I can "get away" with doing something that I wouldn't do if it was "Normal Fluid Service". But that's just me.
Got it!
